Decent quality, durable air hoses??
12/23
I'm looking for a brand name of air hoses that may be a little more expensive but might last me a little longer than 6 months. I've been changing our hoses, (or at the very least cutting off the last foot or so) every 6-8 months and it is getting tiresome. They crack so incredibly easy. After a year they are DONE. Cracks all the way up the line. I am using a large compressor with a dryer built in and we have drain valves we empty everyday that normally have no water in them whatsoever so I don't understand what could be causing them to wear so fast. I'm open to suggestions if you think there is something I can do to make my current hoses last longer. I'm spending about $30 for a 50 ft. hose now, if that says anything about the quality.
12/23 #2: Decent quality, durable air hoses?? ...
Have used Flexeel by Coil Pneumatic for years. Last a long time, eazy to repair polyurethane hose. Lightweight!
Robb
12/23 #3: Decent quality, durable air hoses?? ...
Just a thought....it sounds like they are just cracking at the ends where they hook up to a tool, correct? If so then the reason they are cracking may be the constant strain from bending the hoses. If this is the case then you could try using ball connections at your tools to reduce the strain on the hose, and improve the tools flexibility.
good luck,
JeffD
12/23 #4: Decent quality, durable air hoses?? ...
Thanks Jeff. They do start near the tool, from bending, but after a few months the cracks go all the way up the line. I don't want to use a poly hose as they aren't very flexible and we have ours hanging from the ceiling.
12/23 #5: Decent quality, durable air hoses?? ...
It almost sounds like your hose may be being attacked by a chemical source. Does your installation include an inline tool oiler? Is the hose exposed to, or wiped down with a solvent? Does the hose get exposed to a lot of sunlight or ozone?
12/23 #6: Decent quality, durable air hoses?? ...
Last year I bought a rigid air hose from the big orange store. It is a little smaller in diameter, very flexable and thus far has outlasted all the other junk I have tried. It was the most expensive hose they had, but I suggest you give em a try.
Kenneth
12/25 #7: Decent quality, durable air hoses?? ...
We've had some Goodyear Pliovic PVC hoses in our shop now for over 12 years.
They come in Orange and Blue and 25' and 50' lengths. They are reasonably priced and we've had no trouble with dozens of them.
We got them at Harbor Freight, and I think they still sell them, just be carefull not to buy their house brand Chinese ones that look like them. The Chinese ones smell like toxic waste.
1/7 #8: Decent quality, durable air hoses?? ...
I'v got hoses from Senco that are 15 years old and still used every day. I bought 1 from harbor freight that lasted only 3 months before rotting away.
1/7 #9: Decent quality, durable air hoses?? ...
That's why you have to get the Goodyear ones, not the H.F. house brand.
H.F. still sells the Goodyear ones too.
1/12 #10: Decent quality, durable air hoses?? ...
Website: http://www.themachinewarehouse.com
Once air hoses start to split, they just continue. I have had good experiences either installing a metal fitting to help with extreme bending by the tool or installing like a spring on the line to help keep the air hose straight. I used to have extreme problems of the hoses being rubbed on a down draft table. To fix this, I simply purchased some clear water hose slight bigger than the air hose and slipped this over to help protect against the constant rubbing my operators would do.
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
