Dust Collection
What quick connects are you using?
8/1/13
JeffD
Most of my compressed air quick connects are either from the box store or recycled from auctions etc.. Most of them are also getting pretty leaky! I've found lately when I replace them with new ones from the box store they leak almost immediately these days....cheap junk!
So what are you using that's good quality for a reasonable cost?
JeffD
8/1/13       #2: What quick connects are you using? ...
Nick Christensen Member
Website: http://www.littlesaplingtoys.com
Jeff,
I also have had many problems with the box store quick connects. The ones that I have now are really good, they are called ColorConnex and I got most of them at Northern industrial. I have them on all my air tools and the connectors on my hoses, for 1 year no leaks. I am really happy with them. Hope this helps.
8/2/13       #3: What quick connects are you using? ...
I finally got mad and bought some $15.00 female disconnects from the local hydraulic supply house. A year later and no leaks.
8/4/13       #4: What quick connects are you using? ...
Dennis Everett  Member
Website: http://www.thewoodconnection-sj.com
Dynabrade. They're spendy, but have the highest airflow of any I have seen. Particularly good with high-demand tools such as air-powered sanders and spray equipment. The downside is that they're not interchangeable with the standard hardware store variety. That's can be a good thing because nobody can borrow your tools. :)
8/29/13       #5: What quick connects are you using? ...
We get them from an industrial supply house, rarely leak. Had some from the big box store too. Leak very soon, no good, probably from China.
8/31/13       #6: What quick connects are you using? ...
door shop guy
Milton are the best i have found
I bought some of the Dynabrades and they are lightweight and super nice but...i have so many air tools and so many lines everywhere i would really need to change every single fitting. That would cost a fortune!!
Interchange brand hoses
9/22/13       #7: What quick connects are you using? ...
Frankcw Member
I second the Milton recommendation. I had a similar experience as yours and changed over to all Miltons and have fixed the leaks.
I did alot of research and one rec that I followed was to change both fittings (male and female) and not mix fittings from other companies.
9/22/14       #8: What quick connects are you using? ...
Jeff M
I have had good luck with Foster Manufacturing's fittings. I have had a few of them for 8-9 years. Nothing is more frustrating than hearing a hose hiss all day.
He are the female fittings I use, they are made in Springfield, MO.
http://emurdock.com/3103fosterquickdisconnectsocket.aspx
