Add softstart to std 3ph compressor motor?
10/28/14
When the air-compressor in the shop kicks on it causes a momentary drop in shop voltage that is enough to cause the CNC router to shut off sometimes.
Is there a simple softstart unit that we can put on the compressor to prevent the sharp dip in voltage?
10/29/14 #2: Add softstart to std 3ph compressor ...
I can't answer that question. I would be concerned with the service feeding the system. You should not get voltage drop?
10/29/14 #3: Add softstart to std 3ph compressor ...
Need to check incoming power and wiring situation. I have a 7hp compressor and 2 CNC's. Have never had any problem with anything when the compressor kicks on.
10/29/14 #4: Add softstart to std 3ph compressor ...
It would be interesting to see the running amperage of the compressor. I am going to guess it is a lot higher than the plate on the motor. You likely have a bad connection that is causing the amperage to be high. It would be especially high on start up.
1/31/15 #5: Add softstart to std 3ph compressor ...
Hey look into star delta, it is a method of bringing 3ph online softer.
