Dust Collection
Brent advice
7/6/15
Marci Member
I'm eirking on a furniture line and will be using hardwood and mdf sheets up to 70 inches long that will need sanding. I've got an orbital sander that I can add a vacuum to but am debating between that and splurging for a 30x60 downdraft table. Any recomendations?
7/10/15       #2: Brent advice ...
Karl E Brogger
I've got a 48x72 Denray down draft table, I think it's a 7200B.
It's completely adequate for my needs for clean air. You don't want to cover too much of it when sanding on it though, it defeats the purpose. It doesn't work well on items covering say ¾ of the table
I do think that abrasives last longer when there is a vacuum hooked up to it, and having both certainly wouldn't hurt. I'm kinda surprised I haven't seen a down draft table that had a port on it to connect a vacuum hose.
Mine has an onboard air tank to purge the filters, if I were to order it again, I'd get the model that has a timer on it so the filters were purged on a regular schedule.
