Dust Collection
Dust collection issues
5/11/17
Robert Reed Member
I recently altered my dust collection using my old delta 1hp motor and impeller and an Oneida vortex and a Wynn environmental filter. My wife has named the amalgamation Zoltar.
My shops air has never been this clean.
The chip and dust extraction at each machine is noticeably better.
I mounted the motor vertically in this application, whereas the stock configuration has the motor mounted horizontally.
The bearing on the motor shaft has begun to squeal, after 3 months in this position.
There is no weight on the impeller shaft, its all borne by the motor mounts. The vortex is also self supported.
Obviously I'm about to replace the bearing on the motor, but should I use a stock bearing, or is there a bearing that will function better with the motor mounted vertically?
