Subject: Re: Chemcraft aquprime
Chemcraft aquprime
1/19/15
Dan cook
We are now using aquprime for s primer under M. L. Campbell mangamaxwith good results, however the primer has a lot of orange peel and requires a lot of sanding. Someone suggested aquaset which they said is smoother. I looked it up and it appears to be a topcoat. Anyone use this product or have experience with these products?
1/20/15       #2: Chemcraft aquprime ...
Tony
Dan-I just started using ChemCraft coatings last Spring. I have used quite a bit of the OptiPrime and haven't noticed orange peel. I have been reducing though. It is pretty thick. This may eliminate your problem?
1/20/15       #3: Chemcraft aquprime ...
Brian T
Reduce 15-20%. The first coat will not lay flat. The second coat will lay much flatter after thinning. We tried all kinds of combinations of butyl and other retarders and decided to just thin with water in the end.
We spray between 15 to 30 gallons of this product per week and have been using it for over a year. We use waterborns, pre cats, CV and 2ks over it with no issues.
The only problem with the product if you call it that is it is tough as nails. It's harder then any other primer to cut back. We usually start with 180 and work up to 320 400 grit otherwise sanding would take forever.
1/20/15       #4: Chemcraft aquprime ...
Dan cook
Wow...15-20%. The chemcraft rep said no more than 2%. I will try it though. You say you put 2 coats on. I will try that as well. We have been doing one coat and then sanding back and final coating at least 2 coats of magnamax. It seems to give a good finish but you are right sanding is a bear.
1/21/15       #5: Chemcraft aquprime ...
Mike Fuson
I've been spraying aquaprime, sprayed a lot of it today as a matter of fact. I don't thin at all. My gun that I use has a 2.7 tip. I adjust my gun high pressure and cut back the flow until the Orange peel is gone. I've found that holding the gun farther away helps also. As far as scuffing, we love the way it sands, not hard at all. We use 320 paper and grab new pieces frequently. Be aware of one thing, if you get aquaprime to thick it will crack. The tendency is for it to get thick in corners, it will crack. We use dekone to strain it, that's a must.
1/21/15       #6: Chemcraft aquprime ...
Tony
Dan-sorry, I mis-read your post. I didn't catch it til I read Brian's post and saw the "just thin with water". Guess it may be time for me to quit breathing fumes and start using water borne!
