Subject: Re: filler after primed
filler after primed
2/13/15
tom Member
Is there a product that can be used to fill these holes without sanding back down to raw wood.I have a pic up of the primer I am using.I try to make sure that everything is filled and prepped.Very frustrating.
I will be spraying pigmented lacquer over the primed area. I will be using same product by ML Cambel
2/13/15       #2: filler after primed ...
Leo G
Small holes like that can be filled with a Mohawk Fil-Stik wax crayon. I do this all the time for small holes. Usually I will put another coat of primer over it (spot prime) and then sand lightly. Small holes will be filled flat, larger holes may show a small divet if you aren't careful with the process.
2/13/15       #3: filler after primed ...
tom Member
Thanks Leo
Can you tell me where I can buy that product
2/13/15       #4: filler after primed ...
Leo G
http://www.mohawk-finishing.com/catalog_browse.asp?ictNbr=106
2/13/15       #5: filler after primed ...
Jim Conklin  Member
Website: http://www.jhconklin.net
We use an interior/exterior spackle from DAP. Smear it in with a modelling knife and feather it off when we scuff the primer. Never had a problem (using a pre-cat system).
2/13/15       #6: filler after primed ...
Denny J
Spackle, joint compound and automotive body filler all can and have been used for that purpose.
2/16/15       #7: filler after primed ...
Shane
Use 3m Acryl Green spot putty or 3m white spot putty for small defects like that... no mixing and dries fast with little to no shrinking. I use the green so it really shows when the defect is filled/sanded correctly. anything deeper or bigger needs usc icing. it's a polyester filler like bondo but it comes in a tube and spreads smooth like cake icing.. love that stuff. just spot prime and scuff if you feel your not going to get coverage or bleed through on your paint color.
2/17/15       #8: filler after primed ...
JM
We just use that DAP stuff from the home centres that goes on pink and dries white. No need to sand it back to raw wood. No need to prime over it.
We prime, fill with DAP putty, scuff, topcoat. Never had a problem.
