Subject: Re: Matching old work?
Matching old work?
2/23/15
Evan Member
Website: http://www.near-west.com
When a customer asks you to match older unstained work that has darkened or ambered over time, such as VG fir, Cherry, or Maple, do you stain to match and have it be darker later or keep it clear and tell them that it will all match in 3 years?
2/23/15       #2: Matching old work? ...
Nick Member
Matching clear finished aged wood is as hard and frustrating as anything I do in the shop but I've always taken the approach with my business that it's my job to give the customer what they want...I do inform them what the options and their respective costs are (with the waiting option always being the cheapest...of course) still I would guess 90% opt for matching the existing work...even if I tell them there's no guarantee it will match in time.
2/24/15       #3: Matching old work? ...
shenendoah
before you go kookoo trying to color match an oxidized wood - and I assume clear coating as well?? - get some potassium bi(di)chromate, dilute with water and rag/ brush on some samples with varying proportions of potash to water. Potassium dichromate impacts the tannics - the higher tannic content of the species the greater the impact of the potassium. if that doesn't work for you and you go to staining, use anniline ( not metallic dyes as they are 'light fast') water reducible dyes as they will fade with time and allow the natural oxidation to come forth. water as opposed to solvent as the water is 100%in the wood fiber with no residue on the surface as one gets with solvent borne dyes. perhaps I am being too fussy here , but I learned this many moons ago conserving and restoring antiques and fine furniture. next you need to dye tint the coating to simulate it's oxidation. Good fun.
2/24/15       #4: Matching old work? ...
Depends on the species. To duplicate old walnut, I put a layer of orange shellac under the top coat if it is compatible. Since all older clear coats yellowed, I'd put a little dye in the seal coats and declare it's the best you can do. That is done on color sample boards and with a signature of approval on the back from the customer.
