Subject: Re: Target EM6000
Target EM6000
3/13/15
al
I used the Oxford lacquer from Target Coatings some years ago. While I thought it sprayed very nice and had low odor I found it scratched easier than some other water base lacquers. Is
the EM6000 lacquer the same as the Oxford? I see they have a catalyst for improved hardness
and chemical resistance. I would like to use it on bathroom vanities.
Any thoughts appreciated,
Al
3/14/15       #2: Target EM6000 ...
Bob "Boardman" Borders Member
Overall lacquer (wb or solvent) isn't the best choice for areas that will get a lot of moisture. The 6000 is a much improved version of the original Target product. You might want to take a look at their 8000 whichis a precat CV or the 9300 which is a poly - both have great water resisitance. The best thing to do is call them and speak to Jeff - he'll give you the pro's and con's
3/15/15       #3: Target EM6000 ...
marci
I have spoken to the owner about the products and he recommended the 9300 with the cross-linker for the most resistant surface
