Subject: Re: Varnish
Varnish
3/16/15
Tim
I recently finished a wood door with tung oil varnish that was semi-gloss but I am unhappy with it because the gloss it too high. My question is can I cover the tung oil varnish with a satin or semi-gloss polyurethane?
3/17/15       #3: Varnish ...
Why? Just use Abralon or steel wool to cut the sheen.
3/18/15       #4: Varnish ...
RRM
I also use a tung oil varnish. I suggest using the high gloss version and rubbing it out to any final gloss you want. The high gloss has no additives to adjust gloss and seems harder. The last table I did was rubbed out to 4000. You can stop nearly anywhere you want to in the rubbing out process.
