Subject: Re: Stain problem
Stain problem
3/19/15
Stefano
I staining several frames on black using aniline stain water base. I'm working on forty pieces but 6/7 frames has some kind of white looking like it show the picture. I apply the stain with foam brush and I wipe a cotton rag
Thank you for help
Stefano
View higher quality, full size image (2210 X 1640)
3/20/15       #2: Stain problem ...
Shane
I see Glue..... the stain is not going to penetrate the wood when the pores are sealed with wood glue. seems to me you should be spraying the frames with a small gravity feed hvlp gun at low pressure to color the frames in without getting to splotchy... to me it would be much faster and more even in color too. Many ways to skin a cat though... Re-sand the frames well and the glue should come out...
3/20/15       #3: Stain problem ...
Stefano
Thank you Shane but the problem it isn't only in the corners were the glue is but all around
Stefano
3/20/15       #4: Stain problem ...
Robert Member
Could be from the gloves your wearing.
3/20/15       #5: Stain problem ...
Looks like glue to me, could be from glue on their hands while handling, or from clamps. One darker spot looks like a finger print. Poor handling, and no sanding after assembly.
3/21/15       #6: Stain problem ...
Bart
Are using Lockwood powder dye? I've had that problem in the past when used to use them. I would just do multiple coats. Let dry and keep hitting it till you get the black you want. I would definitely do spray no wipe. Or you could switch to another mfg. I use GF's rtm stains and their black tint is right on the money.
my2cts
good luck
3/23/15       #7: Stain problem ...
chris
spray on your dye stain dont wipe it. then get black wiping stain will help even everything out.
