Subject: Re: Screwed by SW vinyl sealer
4/2/15
Joel
Hi,
So I use SW Pre-cat laq and couldn't be happier with it. But, they won't sell me an easy sand sanding sealer anymore. So I used the vinyl sealer that was recommended. I sprayed a whole house worth of stain grade trim with the stuff and had a hell of a time sanding it smooth before top coat. I missed some nibs and had to re-sand and re-spray some of it. Why can't I get the easy sand sealer from SW anymore?
4/2/15       #2: Screwed by SW vinyl sealer ...
Kevin
im not sure why you would be having a problem with the vinyl sealer. I have been using that for over 10 years with no issues whatsoever. You are talking about T67F6 right?
Im really at a loss. That stuff dries in minutes and sands/powders effortlessly. Try adding 25% lacquer thinner.
4/2/15       #3: Screwed by SW vinyl sealer ...
Joel
I'm not sure of the SW # since I didn't save any. I sprayed it without thinning. We must not be comparing apples to apples because the stuff I used didn't powder at all. It sort of gummed up when sanded. I let it dry overnight.
4/2/15       #4: Screwed by SW vinyl sealer ...
Bruce H
I'd be willing to bet that what it said on the outside of the can was not what was inside. Screw-ups happen.
We spray both vinyl sealer and T77 un-thinned. Both sand well but the sealer is a bit easier.
4/3/15       #5: Screwed by SW vinyl sealer ...
Kevin
maybe you used the F7 which is supposed to be catalyzed with V66V26. Its for their conversion varnish system, and it doesnt sand nearly as well as the F6 precat vinyl. If it gummed up, i can assure you that it was not the F6. I have sprayed thousands and thousands of gallons of it and have never had an issue ( other than the occasional blushing during very high humidity )
4/3/15       #6: Screwed by SW vinyl sealer ...
Mitch Suber
Different product from yours I'm sure. But I use and have been using the T67 F7 for years. I either add a little thinner or none. Never a catalyst. It dries fast and sands really well. I like the way it performs.
You didn't add any retarder by mistake did you?
4/3/15       #7: Screwed by SW vinyl sealer ...
Kevin
mitch. if your not catalyzing the F7 you cannot use it under conversion varnish. If your using the F7 under precat, your kind of wasting your efforts. The F6 is much better as far as dry time and sandability for use under precat lacquer.
That said, I use a ton of F7 as well. Always catalyzed. Only for conversion varnish. These days we spray primarily conversion varnish and do so in high volume. Our cefla goes thru about 40 gallons a day.
There is simple no comparison to the sandability of the F6 to the F7. They are worlds apart in that aspect. But i will say the durability of the F7 is much better than the F6.
4/3/15       #8: Screwed by SW vinyl sealer ...
Mitch Suber
Website: http://subercustomshutters.com
Kevin, thanks for the heads up on that, but we do not spray the pre cat. I was just speaking up mostly about my satisfaction with SW products, usually that is! Plus I was pondering the possibility of the addition of retarder. I find in our paint room, the habit of adding certain ingredients to top coats often causes them to find their way into sealers and primers, where they don't belong.
4/4/15       #9: Screwed by SW vinyl sealer ...
Joel
Thanks for your responses. Maybe they just put the wrong product in the can. Know I know what to ask for specifically.
