Subject: Re: Client wants a brushed finish
4/11/15
tmak Member
I have browsed the forums but have not seen anything related to my question. I am considering a Ben. Moore Advance super white primer and satin paint combo for the finish for poplar kitchen cabinets. I have read that the white may yellow and that the product requires more time than liked by the industry. I am open to suggestions if there is a better product for the application
4/11/15       #2: Client wants a brushed finish ...
RobertJ
Maybe, Annie Sloan Chalk Paint. Personally, I would not warranty the finish. Or, any brushed on finish for a kitchen. If the client wants a 'brushed' finish, use gesso for your first coat.
Also, hard to calculate a price based upon your new application technique....brushing is a slow moving task, like watching paint dry.
Link
4/11/15       #3: Client wants a brushed finish ...
John Member
If you use a WB acrylic paint it won't yellow. Both BM and SW make very nice ones. If you use an airless sprayer to apply it you will have time to go back over it with a brush to get the desired brushed look with much less effort/time.
John
4/11/15       #4: Client wants a brushed finish ...
Harry Devrieze
Pretty much what John said . I use WB flat acrylic paint . Brushed and lightly sanded. Then I clear coat with a matte finish. I like Chemcraft vari-cure.
Color does not yellow of fade and the clear coat give great wear resistance.
Try a sample.
View higher quality, full size image (1280 X 1024)
4/12/15       #5: Client wants a brushed finish ...
Tmak Member
Thanks, which WB acrylic do you use
4/12/15       #6: Client wants a brushed finish ...
Nick
I've done this 100's of times, both in the shop and on-site. In the shop (and on-site if spraying is OK) I spray a coat of fast dry primer (bin, pigmented post cat lacquer ect...) then one or two coats of color (depending on coverage). My local paint store sells Kelly-Moore Dura-Poxy and I've had good success with it; sprays, brushes well and accepts a clear. After the spray coats I wait overnight and then brush on a coat thinned a bit with Floetrol and then if the customer is willing to pay for it I spray on a clear...either Target 9000 or 7000.
Some paints craze like crazy when top coated with a WB clear so make some test pieces before you spray your project.
4/13/15       #7: Client wants a brushed finish ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
I wouldn't trust anything less than CV or 2K urethane in a kitchen, so if someone wanted a brushed look I would retard my 2K primer, spray it on and then brush it like a brush finish. I would then lightly scuff sand leaving the brush marks in the primer and then spray on my 2K paint or CV.
4/13/15       #8: Client wants a brushed finish ...
Robert Member
Its been 15 years since I painted my kitchen with Latex Paint and its held up just fine. Rolled it on and tipped it off. Probably could have added to the effect and left brush marks if it was necessary.
Through the years its been cleaned with mild dish soap and warm water and have experienced no adhesion problems or peeling or lingering odors.
Used I.C.I. Satin in the kitchen ....three different colors and B.M. Satin in the bathroom...two different colors. All coatings have been trouble free for years and wouldn't hesitate to use it again.
