Subject: Re: Hvlp gun
Hvlp gun
4/25/15
Kevin  Member
I am looking for a good gravity hvlp gun to spray pre cat lacquer with. I build mostly furniture and cabinets. I don't do a high volume of spraying would use about 2-3 times a month. Also what tip size would you recommend the product I have been using is valspar pre cat self seal.
4/25/15       #2: Hvlp gun ...
CraigM
Website: http://www.midnightfinishing.com
I have a Binks M1G that I use on small jobs and don't want to bother flushing lines on my main guns. I really like it, I use either a 1.2 or 1.4 fluid nozzle for most clears. It's not a cheap gun though...
Binks M1G
4/26/15       #3: Hvlp gun ...
RobertJ
Tell us more....waterborne or solvent, and how big is your shop compressor?
If you want to use something like a Binks Gravity, you will need a compressor producing 10-13 cfm and clean delivery of air.
4/26/15       #4: Hvlp gun ...
mastercabman
You can look into turbine unit but I would get at least a 4stage turbine
If you have a compressor there are lots of guns to choose from
If your compressor doesn't put out enough cfm
You can look into low cfm spray guns
I have the Asturo 5008 and the CA tech Jaguare 100
Both uses about 4-6 cfm
I get real good finish
I usually use a 1.8mm for primer and 1.4 - 1.5 for clear/pigmented coating
4/26/15       #5: Hvlp gun ...
Kevin  Member
My compressor is rated at 11.9 cfm and the product is a solvent based.
4/26/15       #6: Hvlp gun ...
John Member
You could do a lot worse than one of the Qualspray guns. No connection to Jeff Jewitt, just a satisfied customer. He'll give you a specific recommendation based on your needs if you call him.
John
HVLP spray equipment
4/27/15       #7: Hvlp gun ...
Jim Clark
My favorite gun is my Iwata HVLP400.
It's an expensive gun made in Japan.
I use it to paint cars with.
I use a 1.4 tip.
For less money, the Devilbiss Finisline
series does a great job.
4/27/15       #8: Hvlp gun ...
RobertJ
You might want to try 3M's new 'Disposable' Accuspray PPS guns.....the heads are disposable.....have not tried one, but the price is right and it seems to garner good press. Select the 1.4 Nozzle for solvent coatings..1.8 nozzle for waterborne. Lot's of them on ebay/epay!!
4/27/15       #9: Hvlp gun ...
Kevin  Member
Has any one tried the air gunso by iwata the impact az3 hvlp it's like 160.00 just wonder if it's any account?
4/28/15       #10: Hvlp gun ...
JM
Sounds like your compressor may be a little small. I would guess you will be running out of air.
Look into a new compressor along with the gun, or a turbine, or the best option an air assist airless.
4/28/15       #11: Hvlp gun ...
Bill in Oregon
Two very good guns that I'm familiar with run at about 10 CFM - the Devilbiss Compact gun with 510 compliant aircap and the CAT CPR compliant gun.
4/28/15       #12: Hvlp gun ...
afinisher
I'm wondering why you're choosing HVLP?
In terms of atomization quality and speed you would do better with a high efficiency gun, aka reduced pressure.
The Devilbiss compact is a great gun but the high efficiency air cap is the way to go. For less money there is the Devilbiss Plus high efficiency gun which comes with 3 fluid tips. Its a heavy gun but does a good job for a great price.
When it comes to conversion hvlp guns the only reason to choose hvlp is if you're in CA or other locale that mandates hvlp.
As for the promise of low overspray and better transfer efficiency, you'll get all that with high efficiency and get better results and move faster, not to mention saving a few bucks.
4/28/15       #13: Hvlp gun ...
Bill in Oregon
afinisher - Agree 100%, both the guns I mentioned are HTE not HVLP.
4/28/15       #14: Hvlp gun ...
afinisher
correct Bill. Had my part numbers confused on the compact. 510 is the high efficiency air cap.
