Subject: Re: Bubinga veneer grain filling
5/7/15
Kyle
We specialize in building conference tables. We use Bubinga veneer a lot and it always has a substantial amount of large and small checks after we press it to a MDF substrate. Our finisher has used Polyester coatings to fill the veneer in but this is very time consuming to apply and properly sand out. What products could we use to fill the veneer in the shop so our finisher isn't spending so much time in the finishing room. We generally always have a 3 inch wide solid wood edge glued to the panels. This product would have to not affect the edge color in any way as the product would be applied to the veneer and solid edge. Thanks
5/7/15       #2: Bubinga veneer grain filling ...
Kevin
try paste wood filler. or if the voids are too big for that you could use epoxy resin thickened with fumed silica and colored to match with dye powder.
5/7/15       #3: Bubinga veneer grain filling ...
Shane
Your finisher is using the best approach available to him with using polyester... using paste filler is very labor intensive and messy. shooting a couple coats of polyester is very efficient.. and it very efficient if your have a widebelt sander with segmented platens to finish sand with. we have a Heeseman sander with segmented platens and finish sand all our flat parts with it. The only better option would be to have a U.V. roll coating line with filling rollers. Our shop roll coats all of our full fill finishes and it allows us to fill grain and still be safe with total system mill thicknesses. We don't worry about our finishes cracking later.
5/10/15       #4: Bubinga veneer grain filling ...
Leo G
Depending on how wide the checking is he could use Mohawk Fil-Stiks which would substantially reduce the time it takes to level the finish out. And it would be color matched to boot.
5/11/15       #5: Bubinga veneer grain filling ...
Max Neu
you could try hot hide glue.Brush it on, rub it in with a rag, squeegee off the excess, then sand after it dries.
