Subject: Re: Curry stains on white Matador CV
5/22/15
Nathan Member
Just got a call from a customer who we installed a kitchen for a couple weeks ago. She dropped a pot and spilled yellow curry on the cabinet doors and back of island. She did wipe them up right away and it cleaned right off island back, but not off the doors. Finish used was Becker (or AcromaPro) Surfacer/Matador, over Maple/MDF raised panel doors. She tells me "I thought you said this was one of the best finishes, how is it some food stains it so easily?". Just wondering if anyone has had similar problems and might offer a solution for removing the stain and if this is typical of curry.
Thanks,
Nathan
5/22/15       #2: Curry stains on white Matador CV ...
Robert Member
You might try paint thinner or Naphtha to remove the stain.
Curry ( a whole bunch of different spices ) gets its main Yellowish color from Turmeric Root. I use lots of it in smoothies and rice dishes and various juices. Silly as it may sound....I use gloves when using it.
Turmeric stains everything it touches and can be difficult to remove. Ancient rug makers used it as a dye. Its a pretty steadfast color but the solvents may work to remove it.
Depending on the sheen of your topcoat it may require a bit of extra coaxing on a duller sheen that a shinier one.
5/22/15       #3: Curry stains on white Matador CV ...
Leo G
Because we all know it was your fault she spilled it on the cabinetry....
If it's a conversion varnish with a TR6 rating you can use just about any solvent to try to remove the stain. Start with simple, isopropyl alcohol which is very mild, then denatured alcohol, then paint thinner, then naptha. If those don't touch it start into the lacquer thinners and acetones.
I assume she did the soap related cleaning.
