Subject: Re: Kremlin vs CAT
Kremlin vs CAT
5/26/15
al
A thread below this one talks about a Kremlin spray gun and how expensive simple parts
are for it. Are the parts costly for CAT products also? Also when using an AAA do you need to thin pigmented solvent CV? I thought no thinning was needed when shooting
with an AAA.
Thanks,
Al
5/27/15       #2: Kremlin vs CAT ...
JP Member
I have a CAT waterborne AAA with a bobcat gun. IMO the parts are expensive, just like the Kremlin. You have to purchase through a supplier.
5/27/15       #3: Kremlin vs CAT ...
JM
I have the CAT pump with bobcat gun. Parts are more or less the same.....give or take a few bucks.
We thin our pigmented stuff about 20%. I guess how much thinning you need to do will depend on what product you are spraying. Our sealers and clears we do not add any thinner.
5/27/15       #4: Kremlin vs CAT ...
herb johnson
just swent thru my recordds,
the repair kit complete for the cat is like 99 bucks, the cartridge alone for teh cremlin is 145.oo plus you need all the seels
good luck
herb j
5/29/15       #5: Kremlin vs CAT ...
Denny J
I have the CAT as well as a Merkur. IMHO the Merkur is a better unit than the CAT. The gun has a better fan pattern and the pump is significantly quieter in operation. All the units are great, spray better than airless or pressure pots and the parts are expensive.
Buy the one that has the best tech support in your area.
5/29/15       #6: Kremlin vs CAT ...
al
Denny,
Can you give me the model number of your Merkur pump and gun?
5/30/15       #7: Kremlin vs CAT ...
Denny J
G40 gun and the 15:1 pump
