Subject: Re: Production Finishing of Shaker Boxes
5/29/15
Rich
As a semi-retired professional woodworker (just sold my closet business) I'm going crazy trying to efficiently sand and finish my cherry oval boxes. After water soaking, bending and drying, the surface is quite rough and with the overlapping "swallowtails" and copper tacks, sanding is quite tricky (using finish sander). This is followed by tung oil and a top coat of paste wax. Gives a nice hand rubbed look but at this rate I'll be giving them away. Suggestions on the sanding and/or finishing process? Thanks in advance.
5/30/15       #3: Production Finishing of Shaker Boxe ...
Pete Anderson
Website: http://petesfloors.wordpress.com
Do you polish with steel wool after the first coat of oil has hardened?
I use #2 steel wool before a second coat of oil. after the second coat has hardened a coat of wax will protect the finish.
5/30/15       #4: Production Finishing of Shaker Boxe ...
Rich
Thanks Pete, as I've been stumbling through this process, I've tried using steel wool to apply the wax, giving it an aggressive working in. The finished product is nice but again, too slow and difficult. I will definitely try your suggestion. To ease sanding, I've also been thinking of soaking the bands, letting them dry flat then giving them a finish sanding. Theoretically, after already raising the grain and leveling the surface, another soak for bending shouldn't raise the grain again, so the final sanding should be minimal (theoretically). I'll let you know how this works out.
5/30/15       #5: Production Finishing of Shaker Boxe ...
Denny J
Supermax Superbrush
5/30/15       #6: Production Finishing of Shaker Boxe ...
JeffA
Rich, glad to see you are out of the closet...business. Now, without seeing any photos or knowing the sizes, I had a furniture account that did a lot of chairs. They had these tumblers that clamped the chair in and had them half filled with glass balls and they would tumble around the chair which really didn't sand but pound the finish smooth. Then they would hand sand where the clamp was on the flat part of the seat and then topcoat. If these oval boxes could fit in a 5 gallon bucked and you might be able to make your own tumbler to sand/pound the finish smooth.
5/31/15       #7: Production Finishing of Shaker Boxe ...
Rich
Thanks guys, it looks like the simple solution will work - sanding after raising the grain pretty much does the trick. Very little work needed once the boxes are formed.
Problem solved.
