Subject: Re: conversion varnish
conversion varnish
6/2/15
Hi, I'm in a bind. I have used SW cv in the past, but for convenience on this kitchen job tried Lenmar. Big mistake. The second coat has major micro bubbles. Lenmar says add a retarder which my local supplier does not carry. I've tried filters, many different air settings but no change.
Out of desperation I mixed up a batch of SW left from a previous job and applied to the back of a drawer front. Perfect. No bubbles. Sw says i should be able to spray their product over lenmar, but....not going as far as to say for sure.
Anybody have an opinion?need to get this out of the shop.
Thanks for your time.
6/3/15       #2: conversion varnish ...
Pete Anderson Member
I have coated over different brands and they have been compatible. The dried resin is very stable. Sand or scrape to make a smooth surface before spraying.
Pete
6/4/15       #3: conversion varnish ...
Jim Herron
I spray Gemini Coatings now, after a stint with Lenmar (recommended by a local supplier that previously stocked Gemini).
While the Lenmar products are ok, I experienced on/off fisheye with their precats and their stain programs make no sense at all- you MUST order a case of 4 gallons of the SAME stain in order to get it shipped or they will ship you 8 quarts at 40.00 a qt. A typical job for me requires 2 gallons sometimes of differing colors. The local supplier stocks some of their stains in qts (1 ea).
WT_ can you do with one quart of stain besides run out and get aggravated?
Aggravated, I contacted Lenmar directly and after several heated calls for a rep, got no calls returned. The janitor finally explained that they had NO stain stocking dealers in the Dallas, Houston or in fact any TX area and saw no need in trying to penetrate a 20 million population market!
Maybe they need new sales directors or company management. Lenmar is a BenMoore stepchild of some sort.
I told the local to send a truck to pick up all their clears, sealers, and retarders from my shop.
Back with Gemini and pleased with their products and service.
