Subject: Re: contact adhesive, veneer and finishing
6/5/15
David Member
We have a on going contract veneering maple veneer onto plastic wire channel covers thousands of feet at a time. The veneer is a paper backed 6" wide roll. We use Premier 925 adhesive to glue it on then it goes into the vacuum bag with a negative form to press it against the curves on the edges. We ship it raw, no finish, back to the customer. They just asked us what to use to field stain and finish the pieces. We obviously don't want to have our recommendation make any of the glue fail. My first thought is waterborne stain and topcoat as long as they are conservative with the application until the surface is sealed good. I am wondering if anyone has experience in something like this, thoughts or has any recommendations for product or method
6/5/15       #2: contact adhesive, veneer and finish ...
Leo G
The paper is an isolation barrier. You should be able to use any coating on it.
I did a large desk using the flammable red contact cement and then a solvent conversion varnish with no issues.
6/7/15       #3: contact adhesive, veneer and finish ...
JeffA
The paper on the veneer is not a barrier. I have had major bubbling issues with paper backed more than with any other and we used an all water based system. I wouldn't commit to anything unless you test and get more money for the testing.
