Subject: Re: Question, applying stripper
7/13/15
Jim
I have noticed all strippers say to only apply stripper brushing in one direction. Not back and forth? Why is this and how does this help? ?
7/13/15       #2: Question, applying stripper ...
Robert Member
Sounds as if your using the thick kind. The idea behind over brushing is that once you've got a nice thick coat on, its best to leave it alone so the wax can rise to the surface. This creates a kind of blanket and that wax blanket prevents the chemicals from evaporating.
Brushing back and forth a time or two wont hurt anything,just don't overdue it.
9/6/15       #3: Question, applying stripper ...
Scott Garnett
You'll do best if you apply your stripper in the same way that you'd lay frosting on a cake. A nice thick layer is always better than a thin skim. Brushing in one direction helps you apply a thick layer, in addition to not disturbing the wax "crust" which keeps the stripper from evaporating.
