Subject: Re: sanding with orbital then block sanding
7/17/15
scott Member
I am working for a company and when sanding anything such as a 5 piece door or even a flat end panel after they use a random orbital sander they block sand after. To describe the process better after our parts come from the wide belt sander or to our finish prep area the workers will sand with an orbital sander with 180 grit. next after sanding the part with the orbital they will either block sand the part or use an inline sander with 100 grit. the lead in the department says it is for the stain to penetrate better and to remove the orbits. my question is why sand with 180 if you go back and block sand with 100 grit. is this a pointless step? Or should they be block sanding with 180 grit. please let me know so I can get this issue fixed
7/17/15       #2: sanding with orbital then block san ...
Jim
Scott, go farther down to an excellent post dated 2-1 , "sander issues"
They cover exactly the question you are asking! As in all woodworking there are a variety of opinions. ......but they give an excellent starting place for your own comparison experiments. ......just jim
