Subject: Re: filling with polyester?
7/29/15
nick
A customer wants a full fill on his mahogany table, I'm thinking of filling with polyester but I never done it...for those of you who have please clue me in...thank you in advance.
7/30/15       #2: filling with polyester? ...
Kevin
we do this alot. start with barrier coat. then scuff and spray a nice fat coat of poly. wait 24 hours, sand back until grain disappears. If you start to burn through before the grain is gone then your going to need another coat. Once you have everything nice and flattened out, topcoat.
7/31/15       #3: filling with polyester? ...
arthur grudko
If you do this on a grainy wood, be prepared for a lot of shrinkage over time. Sometimes, depending on the grain, it's a deep line shrinkage that you can put your fingernail in.
7/31/15       #4: filling with polyester? ...
Shane
word of advise when mixing your polyester... after your batched up pour about 4 oz. in a mixing cup and keep near by and keep an eye on its viscosity changes... it could save you a set of hoses... when polyester starts to kick over it happens pretty fast so you will need to keep an eye on it..... flush immediately all your equipment and get the residue off yours seals and things or your never getting it off.
8/11/15       #6: filling with polyester? ...
JT
Nick,
The only way to get a full fill finish is with a polyester. Much shorter pot life but 98% solids product. Milesi has a great polyester and we also provide the technical knowledge to use the product safely and effectively. www.milesi.us.
