Subject: Re: conversion varnish
conversion varnish
8/19/15
Dennis Trombetta
I recently had a bar finished with conversion varnish. When cold drinks or hot items (recently a pizza box) are set on it they leave marks mirroring the item. Can this varnish be sanded just enough to remove the markings and then refinished with poly. Will the poly bond to the varnish or does this need to be sanded down to bare wood?
8/20/15       #3: conversion varnish ...
Bill Richardson  Member
Website: http://www.awwtx.com
That was not properly applied conversion varnish. If it was indeed conversion varnish, the proper amount of catalyst was not used. You need to go back to the individual that applied the finish.
As to putting another finish on top of what you have, the answer is no. The existing finish is improperly cured, and any finish put over it will fail. That finish needs to be stripped before another applied.
8/21/15       #4: conversion varnish ...
Shane
I second that..... you did not receive a conversion varnish finish and if you did then something was not mixed correctly. it's highly unlikely conversion varnish would be acting that way unless the mil thickness was incredibly low ...... I bet they used a nitro or a cheap pre-cat lacquer that had on hand
8/21/15       #5: conversion varnish ...
sean
I concur. You have to remove the old finish or the new finish will fail. I just redid an entire 40 foot bar top in a restaurant. The existing finish was sticky to the touch and had white blush marks everywhere. Prob from sub part coatings used from whoever finished it before me (I was hired to redo someone else's work). Stripped that entire bar in one day (with 3 laborers) and refinished in 2 days. I used that new polarion 2k poly from ml campbell. The bar is now bullet proof and the owner is pleased.
8/21/15       #6: conversion varnish ...
JT
Agree as well. However, I would recommend Milesi's urethane product for the bar top. www.milesi.us. They are the market share leader in Europe and part of IVM Chemicals. They have Distibutors across the US.
8/21/15       #7: conversion varnish ...
Shane
The Milesi catalyzed poly would be the right coating for the job...... That stuff lays out nice..... bullet proof if mixed and sprayed correctly.... perfect for a bar
