Subject: Re: Vinyl Sealer Problems on Mitered Doors
8/31/15
sean Member
We are having a recurring finish problem on a certain mitered door. The problem exist only on white vinyl sealer finishes, only in the profile of the miter, which is an inside bevel that is 1 in wide. After several months a bubble develops in between the finish that cracks and flakes off. The bubble is occurring between the first and second coats of sealer, meaning that everything flakes off, clearly leaving the first coat behind, well bonded to the door. Our finish schedule is 1 coat vinyl sealer, sand with 220, fill any defects, second coat vinyl sealer, pre-cat lacquer, sand, pre-cat lacquer. The doors are 1" soft maple with 1/4 maple mdf core flat panel. Any help or guidance is much appreciated!
8/31/15       #2: Vinyl Sealer Problems on Mitered Do ...
Leo G
Don't do the second coat of Vinyl Sealer.
9/2/15       #3: Vinyl Sealer Problems on Mitered Do ...
Max Neu
That sounds odd,you shouldn't have any adhesion problems with vinyl sealer.When you fill voids between the 1st and 2nd coat,do you recall filling gaps at the miter where the problem is?Maybe the filler you are using is leaving a residue behind causing the adhesion problem.I could see where something like "Fast and Final" could cause a problem like that.
