Subject: Re: Gun cleaning
Gun cleaning
9/10/15
Stefano
I wonder if someone can suggest me a efficient way to clean spray gun. I spray only water base lacquer and in the end of the day I wash the gun with warm water and soap follow by lacquer thinner. Seem to me it's work well but maybe I should do in a different way?
Thank you Stefano
9/11/15       #2: Gun cleaning ...
Kevin
ultrasonic cleaner. not very expensive. do a search here, theres a thread that talks about them. I ended up buying the one that they mentioned and it works very well.. I believe it was around $150
9/11/15       #3: Gun cleaning ...
herb johnson
here is a good way to do it and it works
buy a gun cover, they cost about 3 bucks each, the outside of your gun stays clean
then flush as you normally do
good luck herb j
9/11/15       #4: Gun cleaning ...
simple green solution followed by denatured alcohol to dry the water.
9/11/15       #5: Gun cleaning ...
JeffA
If it ain't broke, don't fix it.
