Subject: Re: Use of Mineral Spirits and/or Linseed Oil as a Temporary Finish
10/19/15
Tommy
When trying to make an unfinished hardwood or softwood piece temporarily “pop”, could one use MINERAL SPIRITS and/or LINSEED OIL, without incurring a problem with the finish later on (say 1 month later)?
We are trying to make the grains of the wood “pop” without using water on the wood, which would raise the grain. So if we could use mineral spirits and/or boiled linseed oil as a temporary application on the wood to give it a temporary finish look, that would be great.
If this is possible, then what quantity of mineral spirits and/or linseed oil should we use?
Has anyone experimented with this before, please let us know?
Thanks.
10/19/15       #2: Use of Mineral Spirits and/or Linse ...
Spicolli
I always use mineral spirits to wet the wood and see what it will look like with a finish. Normally this will dry out pretty quick. I would not recommend linseed oil for this as you may have adhesion issues down the road depending on the top coat. I have top coated the oil with lacquer with success after sufficient time to dry.
10/19/15       #3: Use of Mineral Spirits and/or Linse ...
nick
I prefer DNA because it evaporates quickly and leaves no residue. This is great if you're checking for glue residue, water-spots, or if there is still some finish on a stripped piece since you won't have to wait long before resuming the necessary sanding.
