Subject: Re: Paint booth lights
Paint booth lights
11/3/15
al
Looking at lights for a paint booth. Most of the lights I'm finding are stamped Class 1 groups ABCD Div 2. When reading the
difference between Div 1 and Div 2 it states that Div 1 is when flammable substances exist under normal operating conditions. Div 2 is where flammable substances are not likely to exist under normal operating conditions. The lights I am
finding are Div 2 and labeled for paint booths. Seems to me Div 2 is not the right one but that's what I'm finding.
I'm looking for the right fixtures, any feedback appreciated.
Thanks,
Al
11/4/15       #2: Paint booth lights ...
chris
give this company a call. I have this brand in my booth
ldpi-inc.com
or get a copy of NFPA code33. this is fire agency code specifically for spray booths.
11/4/15       #3: Paint booth lights ...
Paul Snyder  Member
Website: finishing.tips
Al - lights that are attached to the ceiling or walls and are isolated from the spray area by safety glass that's sealed against vapors and dust are Div II. If you have lights mounted inside the booth or use portable lights in the booth, you will need Div I fixtures.
11/4/15       #4: Paint booth lights ...
al
Thank you both. Paul my area for spraying is 6 foot wide by 12 feet long with 92" ceiling.
Concrete block walls, concrete floor and concrete ceiling. If I read you correct when spraying
in this room I need the div 1 type fixtures.
I see spray booths online that use the div 2 type fixture but they don't hang in the booth just the glass access door to get to the bulbs is visible. So I guess the thinking is the housing is
on outside of booth in different environment. I do have one wall that will be constructed of
something other than concrete, this wall is opposite the fan. I was considering mounting
(2) div 2 lights in this wall standing upright so all that would be visible when spraying is the glass door. And then over where the fan is and where I'm primarily spraying an overhead div 1 fixture.
It seems like with the lights on the wall like this it will make for good glare on piece i'm spraying. I seldom spray large pieces and rather just parts and then assemble so my spray
area doesn't have to be huge.
11/5/15       #5: Paint booth lights ...
Paul Snyder  Member
Sounds like you have a good plan Al. Get a copy of the national fire code as recommended by Chris. Following it will help keep you out of trouble with the Fire Marshall, OSHA, and your insurance provider. You can find the code on-line via some of the spray booth and booth lighting manufacturers.
11/6/15       #6: Paint booth lights ...
chris
the electrical conduit will be different also. for div.1 it will have to be explosion proof too. threaded conduit and fittings.
make sure you get an electrician who knows what is needed.
