Subject: Re: finishes on mdf veneered and banded mdf kitchen doors.
11/23/15
Nancy Wallis/Svens Refinishing Member
I'm having trouble getting finish to stay on the edges of kitchen doors that are birch veneered and edge banded mdf. Per the customer he doesn't want the edges eased. The finish is strong on the fronts and backs but you can scrape it off on the sharp edgeswith your fingernail. I've been spraying for years, I'm not missing the edges.
11/24/15       #2: finishes on mdf veneered and banded ...
Leo G
You need to break the edges. A sharp corner won't hold finish.
11/24/15       #3: finishes on mdf veneered and banded ...
TPG  Member
This works well on the edges
https://www.youtube.com/watch?v=kLqPZdAKnsE
11/24/15       #4: finishes on mdf veneered and banded ...
Denny J
If he doesn't want the edges eased have him sign off that he accepts all liability for finish failure on the edges.
11/30/15       #5: finishes on mdf veneered and banded ...
The Cajun Craftsman Member
Website: https://www.facebook.com/CajunCraftsman
You need to school the owner on surface tension. Explain to them that the sharp corners cannot hold the paint from being drawn back to flat on the substrate because of the lesser resistance. One slight pass with 150/220 grit will suffice enough to alleviate the problem. A radius of say 1/64" would be negligible and still look sharp to the naked eye. You can't argue with physics and the properties of drying paint.
