Subject: Re: Premature Finish Failure
1/17/16
Stewart Member
Hi All,
I clear finished a maple kitchen with flat fronts (grain matched and edgebanded) about three years ago with a Valspar pre-catalyzed lacquer. About three months after delivery, the client called up to say there were white spots beginning to show along the bottom edge of some of the doors/drawer fronts. So, I repaired them scrubbing some of them down to bare wood and completely refinishing. This seemed to take care of the issue until I just got another call saying the same thing was happening - only worse this time. I have had excellent success with pre-cats. Thank God I only tried the Valspar on a couple of projects. I never got a call back on the other one and when I went to inspect this kitchen the other day, it still looked pristine - except for the 15 or so fronts with the white along the bottom edge. I'm pretty sure this is moisture wicked up behind the finish but can't figure out why it would be only on some and not all - and, no, it's not the panels around the sink. These people are really clean - I didn't see any signs of abuse. Could someone shed some light on this for me? How would you guys handle this since I am well out of my warranty period? I'm kind of minded at this point to just replace the infected fronts at my expense since this is obviously premature wearing. What would you do? Thanks in advance!
1/17/16       #3: Premature Finish Failure ...
BobJ Member
Sounds like maybe a contamination issue, did you use a sealer? Are they just white spots or are the spots scale like which would indicate contamination? If it were me I would stand behind my work an would either replace or repair the infected fronts. To me the purpose of a warranty is not to cover this kind of issue.
1/17/16       #4: Premature Finish Failure ...
Robert Member
If you upgraded to a more durable coating it just may solve those issues.
1/18/16       #5: Premature Finish Failure ...
I've never had good luck with precat in a kitchen. The one I built in my house included. The luckiest one I had was when I had gotten a call that they didn't like the durability of the finish. 2 weeks latter, a washing machine hose breaks on the second floor while they were gone. The entire kitchen was ruined and replaced. They did not come to me for the replacement. No, I did not send my cousin over there to cut the hose!
1/20/16       #6: Premature Finish Failure ...
Stewart Member
Bob, I had wondered about contamination as well but the location of the white spots would almost seem to indicate more of a moisture penetration. I'm also wondering if something wasn't right with the finish batch - I've heard of that happening before too. Yes, everything was sealed and applied according to spec. I was in the process of trying several different finishes to see what worked best for us. I have considered going to a more high performance finish - but also wanting to move toward a healthier shop environment. Rich what have you found success with? Thanks again!
1/20/16       #7: Premature Finish Failure ...
BobJ Member
Stewart,
The best finish (imo) for kitchen cabinets is SW's conversion varnish. If you want something healthier use a water borne Enduro Poly by General Finish, they also have an Enduro Conversion Varnish that is water borne but have never used it. The Enduro Poly is a nice product, try it.
