Subject: Re: filling voids after primer
1/20/16
scott
On paint grade cabinets what are you doing to fill small voids or crack lines before final coats. First we spray Clawlock and look for any voids. We have used famowood and light weight fillers but sometimes these don't seem to hold. I'm thinking about a auto body creme filler with catalyst similar to a bondo but i'm concerned that it might over harden or to continue to outgas and blow the conversion finish. Always looking for a better finish. thanks for any insight.
1/20/16       #2: filling voids after primer ...
nick
auto body glazing putty. my local paint store carries it. but if yours doesn't, I'd bet any auto part store does.
1/20/16       #3: filling voids after primer ...
Hen Bob Member
I too used glazing putty for a while, I switched to a product called " Pro H2O EG " from Wurth Baer Supply.
It sands easy and dries super fast. Comes in white/neutral but can be tinted to any color. It seams to take stain decently as well.
1/20/16       #4: filling voids after primer ...
Alan
I agree with Nick.Glazing and spot putty. No catalyst. Comes in a tube. If you go to NAPA, you can get it in grey. Grey is easier to cover than the red. NAPA part #6390, light grey
1/20/16       #5: filling voids after primer ...
rick morehou Member
Nick is right, i always reseal after, just because it takes less time than repairing the finish ....rm
1/21/16       #6: filling voids after primer ...
Leo G  Member
Website: http://www.lrgwood.com
Small cracks and pinholes I use Mohawk Fil-Stik
2/22/16       #7: filling voids after primer ...
PainterDave Member
http://www.autobodytoolmart.com/u-pol-dolphin-glaze-finishing-putty-p-15125.aspx?g
clid=CMnX38fVjMsCFQ6maQodM6oLOA
glazing putty but dont use the red creme hardner because the oxides used to make the red will stain over time unless you leave at least 2 mils of a 2k primer over it
2/25/16       #8: filling voids after primer ...
Pablo
try spackling. doesn't shrink or melt under lacquer coatings. keep it simple,
