Subject: Re: water separator/dryer/filter recommendations
2/12/16
JeffM
I'm putting in a new spray booth. Does anyone have recommendations for a good water separator/dryer on the economical side...around $200-300?
2/12/16       #2: water separator/dryer/filter recomm ...
denny Member
FWIW.....it seems like the Auto Painters are usually at the forefront of this topic.
These guys are rather "affordable".
good luck my friend
http://www.eastwood.com/shop-equipment/air-management/air-filters-and-dr
yers.html
2/12/16       #3: water separator/dryer/filter recomm ...
Your budget will not give you a "good" system. Depends on what part of the country you are in and how much water you have to remove from the air in the summer. Also depends on how much compressed air you are using, what size compressor, and if the compressor is also feeding the rest of the shop. Not a good idea to shop when the only defined parameter is money.
2/12/16       #4: water separator/dryer/filter recomm ...
Mitch Suber  Member
Website: subercustomshutters.com
I purchased a couple of dessicate dryers from Granger and installed them both next to each other. Using only one, never did the job, but the two combined have been giving me excellent results for over 15 years. The dessicate can be oven dried and reused over and over. It has been awhile, but I would guess your budget would get you close to covering the cost.
2/12/16       #5: water separator/dryer/filter recomm ...
Mitch Suber  Member
I found the unit is still available. They apparently have gone up in price, so buying just one would take care of the budget. But I still highly recommend them.
Grainge - Wilkerson unit
2/14/16       #6: water separator/dryer/filter recomm ...
Charles Member
Try a google search for the item Mitch mentioned: "X03-02-000"
I found a number of offers for 108.99.
Two of these in-line, as Mitch suggested, would meet your budget.
3/15/16       #7: water separator/dryer/filter recomm ...
Y. Heller Member
I just went through this myself. I thought I would be getting away spending $300- $400 like you for dry treated air. Nope.
Each filter cost $200 through a wholesaler. We have 6 in total for different sections in the shop. (2 for CNC plasma cutting/metal shop, 2 for the air dryer itself that treats air for the entire shop including the wood shop, 2 for the finishing room)
The best way to dry your air is to get an air dryer that chills the air down. The size of your dryer will depend on the size, HP, cfm, and outlet temperature of your compressor.
example:
Our 120g 10hp 35cfm called for a dryer that was in the $2000-$3000 range. I found a brand new one on craigslist at $800 being sold because of a dent in the outer shell that was replaced by the company. Luck.
But I see dryers go for cheap all of the time on equipment auction sites when a shop closes down. Try looking there.
As for the filters... This will depend on the CFM, temp, PSIG, of your compressor also.
We are using Beko and Hankison filters that run $200-$230 a piece for our cfm flow rate. Yours might be the smaller and less expensive ones depending on your compressor CFM. Maybe more like the $170 range.
Anyway, as it was explained to me by many companies from all the calling around I did, that specialize in air treatment... The best way to get the water out of your system is to run a dryer. The filters only do so much and will end up letting a lot of condensation past them. As well as oil and oil vapor.
I can honestly tell you that this is the driest feeling air I have felt after hooking up our system.
All of the shops I worked at previously before starting my own business would have condensation build up because they didn't have dryers. They had filters in the finishing room of course... And I would open the blow out pipe everyday and watch water come blasting out. And yes, I drained the compressor every morning when I came in to work. I remember a lot of days on the wood shop side when you would go to blow off a piece with an air gun and put lines of water right onto freshly finish sanded doors or panels. I don't miss that.
3/15/16       #8: water separator/dryer/filter recomm ...
Y. Heller Member
Each filter cost $200 through a wholesaler (Scales in Totowa, NJ). We have 6 in total for different sections in the shop. (2 for CNC plasma cutter/ metal shop, 2 for the air dryer itself that treats air for the entire shop including the wood shop, 2 for the finishing room)
example:
machinerymax.com
irsauctions.com
We are using Beko and Hankison filters that run $200-$230 a piece for our cfm flow rate. Yours might be the smaller and less expensive ones depending on your compressor CFM and also. Maybe more like the $170 range.
All of the shops I worked at previously before starting my own business would have condensation build up because they didn't have dryers. They had filters in the finishing room of course... And I would open the blow out pipe everyday and watch water come blasting out. And yes, I drained the compressor every morning when I came in to work (100% humidity NJ summers).
Some filters are better than nothing of course. Hope it works for you if that's the route you go.
