Subject: Re: Sealer over CV if need to re dye?
3/13/16
Darren
A few weeks ago, I was talking to a finisher where I work and he said if you put a vinyl sealer (light barrier coat) on top of your top coat of CV, that you can essentially re dye/adjust the color, (we typically use MoHawk dyes. cuz as you all know, you can't add dye after you spray the top coat of CV
Is there any truth to this?
If so, who's vinyl sealer do you recommend or not recommend, ML, Lenmar, Sher Wil, etc?
Thx!
3/14/16       #2: Sealer over CV if need to re dye? ...
Robert Member
Rather than applying a barrier coat of Vinyl Sealer and then a tinted coat of CV, its possible to apply a tinted coat of CV and eliminate the Vinyl Sealer all together.
As far as the brand of materials, its recommended to stick with the same manufacturer throughout the finishing steps.
