Subject: Re: Kremlin EOS 10-C18 and WB Kem Aqua
5/15/16
B Hand Member
Hello I'm interested in the Kremlin EOS 10-C18 with the Xcite gun.This would be a great upgrade from a pressure pot setup.
I usually spray SW WB Kem Aqua and wondering if I will have any issues. Any advice on the setup pressures and tip size.
Anyone try the new fine spray tip sizes ending in 2?
5/15/16       #2: Kremlin EOS 10-C18 and WB Kem Aqua ...
Nick
I would see if you can get a demo first before spending the 2K first as I prefer spraying wb finishes with a pot and gun set-up. I have found I get better more consistent results then with the AAA. I even changed out my dedicated wb Binks 4-12 pump to spraying solvent clears and bought a couple of stainless steel pots and top quality spray guns and haven't looked back. That said I know of finishers who like the AAA better, hence why a demo is idea.
5/15/16       #3: Kremlin EOS 10-C18 and WB Kem Aqua ...
B Hand Member
Thank You
6/22/16       #4: Kremlin EOS 10-C18 and WB Kem Aqua ...
Gary Member
Just put in 2 of the same pumps here at work and spraying the same product, they work great.
6/22/16       #5: Kremlin EOS 10-C18 and WB Kem Aqua ...
Bruce Hand Member
Hello thanks for the info, I was fortunate to find a used Kremlin EOS 15-25 with the xcite gun.
I recently sprayed 50 doors using the Kem Aqua plus pigmented Lacquer and the finish was like glass, I'm very happy
Air setting were18# and fluid 525#(15x35) using a Cat 36-411f which is equal to a Kremlin 06-072 fine tip
Bruce
