Subject: Re: Veneer Splitting
Veneer Splitting
5/20/16
Dave Member
Website: http://www.north52cabinets.ca
So we have been having this issue forver, we are using a 3/4 OSB cor maple veneer to make in house doors and end result is always splits in the veneer. This time we went ahead and order the "platinum" stuff and its just as bad, any thoughts?
5/20/16       #2: Veneer Splitting ...
John S  Member
Maple veneer splitting in the press is a moisture issue, certainly not an uncommon one here in Wisconsin. It is usually far worse in the winter heating season when relative humidity plummets inside buildings, than in summer when humidity is higher.
Maple is a very unforgiving species when it comes to moisture content, and there is a lot of internal stresses that are naturally present. Winter (actually low relative humidity) accentuates these stresses. Think of what you are doing to that veneer. It comes in "dry", it better be in the 6-8% range or you will have trouble all year round. The first step in pressing is laying that veneer face on a wet glue line, and maybe it sits and "soaks" in the glue for a minute or two. It is adding moisture to the veneer, you probably notice that the sides of the face curl upward away from the core, right? That is because the side of the veneer touching the glue is taking on moisture and expanding, but not evenly because all of the moisture is being added to the back side. So you have a veneer face that is wetter on one side than the other. Some people take it a step further and add more moisture to the face by misting it to decrease the curling (equalize the moisture between the two sides). DON'T DO IT! That only increases the overall moisture and when you put it in a hot press, that moisture will have to be forced out again.
So you take dry veneer, put it on a wet glue line, maybe add even more moisture to get the veneer to lay flat, and then put it in a press which will vaporize that moisture and force it back out of the veneer. What do you think is going to happen? That moisture will escape, it will find a way, and an opening in the veneer (a split) is the easiest route for the moisture to escape.
The keys to success are 6-8% MC in the veneer to start with, and minimizing the "open time" that the veneer sits on a wet glue line waiting to be pressed.
