Subject: Re: Paint vs. Lacquer
Paint vs. Lacquer
6/8/16
Tom Miller  Member
Website: http://www.dreamkitchencrafters.com
I have been spraying lacquer for about a year using an HVLP unit with good results. Just yesterday one of the contractors I work with asked me to finish a laundry room job with latex paint instead of lacquer. His reasoning is that lacquer is impossible to "touch up" in the field while paint does not pose that problem. My question is this: Is it unusual to paint kitchen/bathroom cabinet with paint, is it less durable, do you/would you recommend it. Do you have to spray a clearcoat on top of the last paint coat? What type of primer would you use? I have never sprayed latex paint and would appreciate any and all advise. I typically use hard maple plywood and stock for painted cabinets.
6/8/16       #2: Paint vs. Lacquer ...
Nick
yes, it done all the time. if you choose the right product you can end up with a beautiful, durable finish that's easy to touch-up.
for primer try bin pigmented shellac; alcohol thinned, fast dry, easy sand and will not swell up mdf.
for a finish try SW acrylic/alkyd; good blocking and durability when cured, thin consistency so you could spray with a hvlp, and easy to brush touch-up.
6/8/16       #3: Paint vs. Lacquer ...
Mastercabman
For me,i wouldn't do it
Don't like latex
For walls/ceilings fine but not cabinets
Yes I know there are much better than what it was years ago
But it just take way long to dry/cure
And you really have to thin it hard if you going to use an HVLP
Touching up lacquer is not that bad
6/10/16       #4: Paint vs. Lacquer ...
You don't say what kind of lacquer or what kind of latex. Straight nitrocellulose does not have a lot of moisture resistance, precat is not a lot better around hot water and steam. Cabinets around a sink may not fair that well. By latex, is he talking about a water based enamel? Just choose the correct product and fit your gun out for the viscosity and water based is good for the job.
6/23/16       #5: Paint vs. Lacquer ...
John Bishop  Member
Website: selectwoodworking.net
I would spray it with a cats blood if old boy paid me to. Do what the customer wants. He is probably an old school dude. I have been doing this stuff for 30 years. Some time ago many people did stuff just like that and the builders used it as a sales tool and clients ate it up. I still know guys who build cabinets on site and have them site sprayed and they look great. These are pros.
