Subject: Re: How Hard Is This, Really? - Glaze Coat
7/6/16
Ray Member
Hey everyone, first time on the forum. I saw this video and want to know just how hard this actually is because it looks really easy in the video. Has anyone done this before?
Glaze Coat Video
7/6/16       #2: How Hard Is This, Really? - Glaze C ...
Bob
I have done this type of application on many occasions. Very simple to do but the video did not stress a few important facts.
1. The surface must be perfectly level or you will not get an even finish. This is a self leveling product and will flow to the lowest point if not level.
2. Has to be in a dust free environment when applying. This product takes time to dry so any air born dust will accumulate on the surface.
3. Pour several coats rather than 1 thick coat. Takes longer but it will look better at the end. After 1st coat dries,(usually after 24 hrs.) lightly sand with 220 paper, remove dust and apply second coat.
4. DO NOT use the same containers over again to mix the product. I learned this from experience. For some reason, the second mixing will be contaminated by the residue from the first mixing.
5. Last thing. If you get bubbles trapped in the finish, don't panic. After the coat has cured, drill a small hole down into the bubbles from the top (about 1/8th inch dia.). Lightly sand the surface and pour another thin coat. The bubbles will fill along with the drilled holes and will not be visible when cured.
Hope this helps.
7/7/16       #3: How Hard Is This, Really? - Glaze C ...
I did an EnviroTex epoxy finish on a recycled chestnut conference table about 15 years ago. I was not impressed with the final hardness. I had to fill a million holes first to get a decent surface so epoxy seemed like the appropriate top coat. It went on easy(I've got plenty of epoxy boatbuilding experience). The propane CO2 trick works well on the bubbles.
I would not recommend it. I would look at a 2 part poly first.
