Subject: Re: Achieving open grain
7/8/16
Ron Member
I have been placed with the task finishing american oak doors, however the client is intent that they want an open grain look, with a semigloss white painted finish. I am having trouble as the oak sands up very smooth and traditional paint (oil or acrylic/latex) fill the grain almost instantly.
I have toyed with ideas from white wash followed by clear lacquer to acid etching the face for extra grain definition.
The first picture below shows the clear soaking into the grain to make the surface appear more defined. I am trying to achieve this with a colored coating like the second picture.
Any ideas would be greatly appreciated.
View higher quality, full size image (485 X 501)
7/8/16       #2: Achieving open grain ...
Shane
Both finishes are essentially low solids film coatings. It can be done with a variety of products. If you are going the precat lacquer route you could reduce your sanding sealer or vinyl sealer 1:1 with appropriate solvents..... sand back very flat and top coat with a reduced 1:1 precat topcoat off your choice... I would taylor your topcoat with a good bit of retarder to keep the streaking down and overlap well. Keep the coating wet all the way to the end to prevent streaking of sheen. Pretty much the same for the bottom finish but its a pigmented finish. you could reduce a max tint load vinyl sealer for your base coat sealer and reduce it way down and build your color. sand flat. Wipe a reduced/retarded white glaze and clear reduced topcoat of your choice...... Low solids acrylics will work well for these finishes too..Main things is not getting too much film build and really good flat sanding without burning your color with sand throughs.
7/8/16       #3: Achieving open grain ...
afinisher
An excellent product for this objective: Sherwood Vinyl Basecoat system. For opaque, shoot full strength.
Sherwood vinyl basecoat PDS
7/8/16       #4: Achieving open grain ...
Jared
We do this finish a lot. Our schedule:
1. Wire brush wheel on electric drill to further open grain.
2. Blow off thoroughly
3. Tinted primer (MLC Clawlock in our case)
4. Conversion varnish topcoat
It's easy and bulletproof.
7/9/16       #5: Achieving open grain ...
RobertJ
Jared's method is the best!!
7/9/16       #6: Achieving open grain ...
afinisher
Some additional info on sw basecoat. This is a very thin material, so unlike a heavy bodied primer, all the natural grain texture shows distinctly without the need to open up the pores more aggressively.
Basecoat may be catalyzed and topcoated with any SW clear coat system.
Personally, I prefer a 2k acrylic urethane clear system over the basecoat to avoid yellowing common with cat lacquers and conversion varnish
