Subject: Re: Gemini Gemvar vs MLC Excalibur
7/11/16
Feuchts Member
Website: http://www.feuchtscabinets.com
We currently use Gemvar 511 conversion varnish and have for over 9 years without any problems. We use it as a sealer and finish coat. We like it because it's ease of use and 21 day pot life. Recently we decided to try MLC Excalibur conversion which is mixed at a pump and has a fast dry time. (Which is the reason we r trying Excalibur) We are using the Excalibur as the sealer and finish also. So I am looking for anybody that has used either of these products and is willing to share there pros/cons of either .finish and which finish they prefer.
7/12/16       #2: Gemini Gemvar vs MLC Excalibur ...
Leo G
I've never heard of MLC Excalibur conversion. All I use is MLC products. Is this new?
8/12/16       #3: Gemini Gemvar vs MLC Excalibur ...
DannyB Member
It's pretty new, The Satin version is C119624 i believe.
"Excalibur Conversion Varnish Clear is a very durable, self-sealing, fast dry, HAPS compliant finish for wood surfaces with added UV absorbers to offer outstanding UV resistance under ultraviolet exposure. Excalibur passes all KCMA tests and AWI System 5 (Conversion Varnish) for chemical and moisture resistance."
They call it "medium solids".
Wurth has it:
http://www.wurthlac.com/storefront/finishing-products-equipment/ml-campbell/clear-
topcoats/excalibur-conversion-varnish-clear-satin/prodML0MC119624.html
8/12/16       #4: Gemini Gemvar vs MLC Excalibur ...
Leo G
After talking to the MLC rep I see no reason to use it. It was designed for production and to be a lesser expensive finish. The medium solids is why it costs less. If you want the traditional mil thickness on your project you will need more coats then say Krystal or Duravar. The only thing I could see me using it on would be Oak. I think Krystal out 30% when spraying Oak so I don't get the grain build because of the high solids.
