Subject: Re: finishing dining room table
7/13/16
Ryan Groff
Hi , I have a customer who bought a new table , but wants to put a more scratch resistant finish on, what is the best finish for this, 2k poly?, can you spray it? It already has a finish on it, don't know what it is, how would you go about this and what finish would you use? Could I put shellac over the finish as a barrier and the new finish on top?
7/13/16       #2: finishing dining room table ...
chris
Get a piece of glass or a table cloth.
or sand down to raw wood and start over. 2K poly has to be sprayed. start with a barrier coat first then sealer and topcoats.
conversion varnish could be used but it is not as hard a finish as 2k poly.
7/13/16       #3: finishing dining room table ...
Bart
More scratch resistant? That's called "patina". lol. It all scratches even glass and 2K poly. I made polyester resin restaurant dining tables in the 80's. Super strong and scratch resistant but even they scratched. Nice thing about the polyester resin is you can resand (starting w/600grt) and buff/polish them out.
Otherwise I'd go with Chris' suggestion. Strip and start over if the budget is there. You could seal it with dewaxed shellac and hit it with just about anything but you might get a call a few months down road. If you go the seal and coat over route make sure your first few coats of your preferred finish is misted to lightly to finally wet. And test for adhesion along the way.
good luck
7/13/16       #4: finishing dining room table ...
MarkB Member
If its a new table tell her to contact the manufacturer and find out what's on the table because you can't proceed without knowing that.
7/13/16       #5: finishing dining room table ...
Bart
[contact the manufacturer ] That's kinda funny. Anything sold out of just about any furniture or box store isn't made in the US. Full sets of dining or master room for under a $1000. I couldn't even come close to buying the lumber/material for what they sell it for. You could do a test on the under side of the table or an inside leg with various solvents. Check the knowledge base here it's been discussed numerous times.
cheers
7/13/16       #6: finishing dining room table ...
MarkB Member
That was my point exactly Bart. Put it back on the consumer. If you do a bunch of underside testing you are effectually guaranteeing your finsih. At best you say "all I can do is try, no guarantees". My theory is let them hang from the rope THEY threw over the limb.
