Subject: Re: CAT AAA waterborne and solvent
7/14/16
al
If I want to spray both waterbase product and solvent cv with CAT brand AAA which model should I buy?
I know they make a H2o model but would this work okay with solvent?
Thank you,
Al
7/14/16       #2: CAT AAA waterborne and solvent ...
chris
why not contact them directly?
http://www.spraycat.com/
7/14/16       #3: CAT AAA waterborne and solvent ...
JoeW Member
I have the waterborne. Its blue and marked H2O. I don't believe there is any other difference. If your going to run waterborne through it make sure all your fittings are stainless steel especially the fluid hose. I assumed that when I purchased mine several years ago the hose was. It was not. It rusted fast.
The spray guns need the F tip to spray waterborne. Its a removable pre-atomizer in the tip. If you don't have it, waterborne is even harder to spray.
I was told you can spray both, but I only spray waterborne.
7/14/16       #4: CAT AAA waterborne and solvent ...
Shane
same pump essentially just a different color and the only real difference is the pickup tube is larger in diameter... true story. Spray waterborne with the pre atomizing orifice. Little more atomizing air than normal and thin passes seem to work best for me with waterbornes..... don't care for them at all....only spray them when we have to for a green job.... otherwise it's /Sherwin Williams Becker Acroma CV for us all day long
7/14/16       #5: CAT AAA waterborne and solvent ...
JeffD
It may be a small difference, but it is different. And I believe the reason they came out with a different WB version is b/c there were some problems spraying it through the regular rig. It's been a few years since I looked into it before buying my rig though, so I'd talk with them and I'm sure they can clarify.
good luck,
JeffD
7/17/16       #6: CAT AAA waterborne and solvent ...
JM
I have the H2O pump and all we spray is solvent. Difference is it comes with larger fluidhoses and a tip with an F suffix (fine finish for waterborne). The H2O setup will spray solvent borne material without any issue. I bout the water version to future proof in case I ever wanted to spray water.
7/20/16       #7: CAT AAA waterborne and solvent ...
Matt
I have sprayed a few waterborne finishes, including a waterborne polyurethane from Sherwin Williams for exterior wood, all of it through a solvent-based AAA Cat pump.
I haven't had any issues, but this has only been intermediate waterborne use, and I've always (always always) flushed the pump afterward with denatured alcohol, followed by clean wash lacquer thinner.
7/20/16       #8: CAT AAA waterborne and solvent ...
al
When you use a solvent cv do you clean with lacquer thinner and leave some thinner in the pump and in the lines?
7/21/16       #9: CAT AAA waterborne and solvent ...
Matt
Yes, always. We use standard wash thinner for it.
