Subject: Re: Pine Floor Finish
Pine Floor Finish
8/12/16
Joe
I am going to be laying some new 8" wide Pine Flooring. It is to be done old school, in that it will be butted edges (No t & g) and face nailed. My issue is the colour. They have requested an aged appearance (see image) but I have yet to match it close enough for their liking. I've tried staining, but as expected it ends up blotchy and inconsistent in Pine. Any suggestions are greatly appreciated! Thank you!
View higher quality, full size image (1082 X 617)
8/12/16       #2: Pine Floor Finish ...
chris
have you tried a clear stain base first. this will help with blotchiness.Or you could spray a dye stain.
what are you sealing and topcoating with?
8/12/16       #3: Pine Floor Finish ...
Arthur Grudko
Get some de-waxed shellac flakes, dissolve in denatured alcohol, and apply until you get a color match. You can leave it as is and wax, or apply polyurethane floor coating. Test for adhesion.
8/13/16       #4: Pine Floor Finish ...
RobertJ
Waterlox + Wax= Aged Patina
8/13/16       #5: Pine Floor Finish ...
Mike Member
I have used (amber) orange shellac when doing repairs on floors that had an aged oil finish on it. Aged oil will amber. I got some good results that way.
8/14/16       #6: Pine Floor Finish ...
Bob "Boardman" Borders Member
The (amber) orange shellac is a decent way to get the color, but it's a lot of trial and error. For this type of flooring my 1st coat is a mix of 1 part finish and 1 part diluted dye.
I use either Homestead dark vintage maple dye, or their orange dye.
I make up a 'master batch' according to the directions, and then make a batch of of 1 part Master mix to 2 parts water or solvent (depending on type of finish you'll be using). I then add this diluted dye mix to an equal part of the finish. I apply this, let dry, and follow up with 2 coats of undiluted finish
8/16/16       #7: Pine Floor Finish ...
Pat
Lockwood Early American Golden Amber powdered dye in water. Play around with dilution to get proper color. These garage cabinets I did look like a pretty close match.
8/16/16       #8: Pine Floor Finish ...
Robert Member
Hi Pat, that's a beautiful color for Pine.Really nice look/job.What are what looks to be a metal clip near the tops ?
8/16/16       #9: Pine Floor Finish ...
kevin
sliding door hardware. notice the door on the hung behind door on right. and the guide on the floor.
8/16/16       #10: Pine Floor Finish ...
Pat
Thanks, Robert. Yep, what Kevin said - sliding barn door hardware, in this case it was inexpensive Stanley hardware that you might find on an actual barn door.
The Lockwood dyes are nice on pine - minimal blotching and easy to apply (just flood it on with a spray gun and wipe it off). Only downside is some of the colors fade from direct sun exposure. They do offer metal complex dyes that are more lightfast if that's something you need.
8/16/16       #11: Pine Floor Finish ...
Robert Member
Thanks guys, I should have paid more attention and looked closer at the hardware but I was mesmerized by that beautiful color.
