Subject: Re: Honey-like Coat on Teak Solid
9/29/16
Ian Dixon
Working in Solid Teak, client has requested a filled and polished finish. This will require a lot of material over oily wood ( makes me nervous).
Will the material stick or release over time?
Water-based or Polyurethane, which is best?
Should the oil be taken out of the top surface prior to finishing?
Other considerations?
9/30/16       #3: Honey-like Coat on Teak Solid ...
Eric Member
Teak has a pretty tight grain to begin with..
Use a grain filler or build out with a sealer..
Sanding to high grit would help.
I'd use a hibuild lacquer or poly..
The oil in teak shouldn't be an issue..
