Subject: Re: Staining Eastern Hemlock
10/22/16
KEN CULBERTSON
Have 2 live edge slabs of Eastern Hemlock that I would like to stain them to look like walnut to make a table top.. I have not work with hemlock, but understand that a pre-conditioner may be needed to prevent an uneven stain. Also will have to plane it to thickness and use a drum sander before staining. So any ideas of best way of staining the hemlock
10/23/16       #2: Staining Eastern Hemlock ...
RobertJ
If you use ML Campbell products and would like to 'pre-stain' just use their Woodsong II clear stain base, then use their Walnut color stain. Could not be any simpler.
As always, make a sample board first, and with a finish on top!
10/23/16       #3: Staining Eastern Hemlock ...
nick
To even out the color difference between softer/lighter and harder/darker grain in hemlock; I would dye it a light to medium brown first, then pre-seal with 1 part finish 2 parts solvent, then stain,, then finish.
10/24/16       #4: Staining Eastern Hemlock ...
RobertJ
I agree with Nick's suggestion about adding a Dye stain.....still need to make a sample board and be careful about diluting the Dye and keeping meticulous notes on application technique(s). Also, many types of Dye stains available: NGR, Alcohol, Water, etc. Can also use a toner as a last ditch effort in the topcoat finish!!!
