Subject: Re: finishing raw wood
finishing raw wood
11/15/16
Charles Earwood Member
finishing inside of new barn. Had all wood milled from fresh trees. Lot of rough wood. Thinking of spraying with spar varnish. Should I seal the wood first or not. All finish is interior. The wood is about 2 months since being milled. How long should I wait before finishing.
11/15/16       #2: finishing raw wood ...
Leo G
You are looking for the wood to reach air dried levels. I think that is 12-15%
11/16/16       #3: finishing raw wood ...
nick
get yourself a moisture meter (You can probably borrow one from your local paint store) and wait until you get to Leo's numbers before coating.
Why spar varnish? I ask because there may be better options. Plus if your inside walls are just the other side of your exterior siding, coating with the same product on all six sides is a good idea.
If this is the case I'd go with a exterior semi-transparent stain...when it comes time to restain/refinish your job will be much easier with the stain.There both oil based and water soluble ones to choose from. A couple of years ago I pre-stained the boards of a 200' long fence in my shop using a San-Sin water soluble stain that could be applied to wood with 22% moisture content. I drive by that fence everyday on my way to work and 2+ years later it looks like I stained it yesterday...that said it's while I'm driving by at 20mph.
11/16/16       #4: finishing raw wood ...
No idea where you live, no idea what wood species, so just guessing. 1 year before finishing. Do it too soon and it will not stick to the wood. Can't imagine the cows will mind if you put finish on the wood or leave it natural!
