Subject: Re: paint gun filter
paint gun filter
11/20/16
Mike Member
Does anyone know of an online site where i can buy these suction gun filters? Where i bought the gun they are 5 bucks each plus shipping. Looking for a better price.
View higher quality, full size image (520 X 1024)
11/21/16       #2: paint gun filter ...
Shane
strain every drop through a paper fine mesh cone filter before painting and you just saved money on those filters and solvent to clean them up
11/21/16       #3: paint gun filter ...
Mike Member
Shane i have always used the paper strainers until i recently started using the Sherwin Williams Kem Aqua plus white. While cleaning the cup at the end of the day i found little lumps of paint about the size of a grain of sugar some stuck to the bottom some stuck on the sides so i started using the screen and also the paper filter. Does anyone know what these specks are? And why this is happening?
11/21/16       #4: paint gun filter ...
Shane
ah ha..... light bulb. What your seeing is the kem aqua skinning on the sides being exposed to air inside the cup... falling back into your material.... the coating doesn't re-dissolve itself... your spot on with those filters... they should help alleviate some of the crud building up between spray outs... I have an ols card stock with little baggies that have metal mesh shaped like cones that go inside the fluid stem that I use time to time.. if I remember I bought hundreds of them for dirt cheap online somewhere.... they have a small clamp that holds them on the stem... just throw away when finished
11/21/16       #5: paint gun filter ...
Shane
Google these AES-45600 paint strainer... various prices around the web on a 60 piece card.. or check finish systems.com they may have some disposables of some sorts
11/21/16       #6: paint gun filter ...
Mike Member
Thank you Shane i just ordered 60 pieces for $49.00 including shipping. 81 cents a piece. And now i know what the little balls of are also.
