Subject: Re: Bathroom Finish Choices
12/12/16
Kevin Member
Going to be spraying some vanities and a tub surround for a customer. Do you think 2k poly with a polyester sealer is going to fly, or should this be an exterior finish? The tub surround is my biggest concern. This is clear, not pigmented. Thanks.
12/12/16       #2: Bathroom Finish Choices ...
nick
2k poly with polyester sealer will more than fly it would be top notch. In wet environs what is just as important as what is on the surfaces that are seen are what's on the surfaces that aren't seen...in other words; prime/seal all six sides of the tub surround with your sealer.
In situations like this instead of polyester sealer i prefer a penetrating epoxy sealer but either will work.
12/13/16       #3: Bathroom Finish Choices ...
RobertJ
Are you sure you need a Polyester finish?
Look at the Woodweb Knowledge base from 2001
Link below
http://www.woodweb.com/knowledge_base/Po
12/17/16       #4: Bathroom Finish Choices ...
Kevin Member
So maybe just 2k poly with its own sealer? I have used verde chiaro from chemcraft with good results.
12/19/16       #6: Bathroom Finish Choices ...
carl
I've had redwood surrounds in apartments for 30 years. At first, then every few years, I go over them with steel wool soaked in 50-50 boiled linseed oil and turps. Sooner or later, they'll rot in the corners. Poly will peel, flake off and possibly get caught in the drain.
2/19/17       #7: Bathroom Finish Choices ...
walter
I would like to ask anyone if I can use my leftover driveway sealer on my granite countertop? Thanks.
best granite sealer
