Subject: Re: Removing sharpie from endgrain
12/20/16
Js Woodshop Member
I mistakenly marked the end grain on pieces of cherry using a black sharpie. I've tried denatured alcohol with minimal effect, lacquer thinner does nothing. Any suggestion appreciated.
12/20/16       #2: Removing sharpie from endgrain ...
Charles
Acetone may work. Try it on a scrap piece first.
12/20/16       #3: Removing sharpie from endgrain ...
I'd use a cabinet scraper. Any solvent will mix with the ink and drive it deeper into the end grain. You didn't mention if it is on raw wood or finished.
12/20/16       #5: Removing sharpie from endgrain ...
Js Woodshop Member
I tried acetone with very little results. It's raw wood so I'm sure the sharpie has penetrated somewhat. I'll try the scraper on a scrap piece. Thanks for your suggestions.
12/21/16       #6: Removing sharpie from endgrain ...
Denny J
Sand it off.
