Subject: Re: What is the best way to setup for spaying long trim
1/20/17
Jon D
Our woodshop handle both residential and commercial woodwork. Our finish department is used to doing a wide variety of items and finishes. Mostly we spray lacquer based paints and topcoats on cabinet face frames and doors. The shop builds and no finishes small batches at one time. Typically no more than 8 cabinets would be flowing into the finish department at once. However, with the commercial work we occasionally get into and no large batch bind.
My issue right now is that we have and about 4,000 lnft of baseboard and did trim in 16' lengths to stain and finish. Does anyone have a better system to setup long lengths other than a traditional rack? We are not setup with any automation in finishing, and the lengths wI'll be tight for moving around. But at this point i am at a loss at to how I can do more than about 400lnft at a time which will basically take over the finishing dept. for 2 weeks.
Any advice would be nice
1/21/17       #2: What is the best way to setup for s ...
RobertJ
You answered your own question: you need automation. Someone saw $$$$ signs and took on this project when they should not have. You need space and a UV coater to get the material out the door.
1/21/17       #3: What is the best way to setup for s ...
Shane
get yourself a Makor Iride 200 on auction... you can spray stain, clear, primers & paints at 120-150 ft/minute. We have two lines.. one for stain,sealer & clear and one for primer & paints.. using precats & C.V. finishes.... we have profile sander/feeder setup in front of the machines on rails to move between the two machines and we have the makor automatic stacker and racks also on floor rails between the two machines.... We can have one man feeding the machine after a profile is dialed in with the guns and speed settings to get a color right. Then we set the laborer loose and run run run.... we have about 12 of the big racks to keep in roatation. we can spray 4000 ft... on the back to seal... colored stain or primer and topcoats in record speed with insane quality..... heck just having the machine without the front end sander and the stacker would still bump your production insanely... but would take a feeder and stacker to load by hand
1/21/17       #4: What is the best way to setup for s ...
herb johnson
get a mm 150 , google it, new about 25k, used about half a real work horse
good luck
herb j
