Subject: Re: lube for WB spray guns?
1/30/17
Nick
what are you-all using to lubricate your WB spray guns?
1/31/17       #2: lube for WB spray guns? ...
Shane
You can use vegetable glycerin with no problems......You can find it in the supermarkets and drug stores.. heck even a good ole tube of KY is viscous glycerin with the added bonus of getting roused by the guys in the shop for having ky in the shop
1/31/17       #3: lube for WB spray guns? ...
herb johnson
mineral oil it is inert and good for this application
good luck
herb j
1/31/17       #4: lube for WB spray guns? ...
Many people use Vaseline. Likewise inert goop that doesn't run all over the place.
2/1/17       #5: lube for WB spray guns? ...
RobertJ
I was told to use Vaseline too. Hence, I use Vaseline. I also cover my face with it if I am spraying for more than 20 minutes!
2/1/17       #6: lube for WB spray guns? ...
Shane
yes absolutely you could lube with Vaseline... but what about handling your gun and traces of that thick viscous Vaseline getting on your hands or gloves and then you get all touchy feely with your workpiece... like feeling the edges and the faces and checking for dust right before you spray... bam... now you have oil on the surface of your faces and edges... Guess what happens if the coating lays down smooth and you forget about it.... well after everything shrinks and cures.. possibly even after installation your client is complaining that the finish is peeling of the edges and the paint has slight bubbles or blisters from delamination between layers... vegetable glycerin are water based lubricants and are actually ingredients in water based finishes.... Just a dab would do around the needle seat and gun screws and you will have no worries about contamination or surface tension problems.... Just my 2 Cents... I only do this for a living and go through over 200+ gallons of coating a week and responsible for the finish quality on over $30 Million dollars worth of wood products a year.
